Inventor Forum
attach axis system to cylinder axis
1 REPLY 1
nicu_bogd
289 Views, 1 Reply
Hi, i try to make an animation. I create a cylinder and i want to rotate it by longitudinal axis. i click 'components', select the cylinder and after i click 'position' to select the axis that axis system appears in the right side of the cylinder not in the middle. If i continue whit this settings the cylinder will rotate by a circle not by his longitudinal axis. How can i move that axis sistem in the middle of the cylinder?
I can drag it but can't place it exactly in the middle.
1 REPLY 1
blair
in reply to: nicu_bogd
Post a picture/screen capture of what you have.
If you created the cylinder at the origin point and extruded in both directions the origin point 0,0,0 would be at the center of your cylinder.
Delta Tau Chi ΔΤΧ
