Inventor General
Active Contributor
oneloosecrank
Message 11 of 38 (247 Views)
Re: assembly constraints and other Qs
10-06-2013 04:13 AM in reply to: oneloosecrank
I completely understand. As a regular contributor in another community, it's a real bore when we take time to assist someone who then dissapears never to be heard from again. My aim is to fabricate this very design as a prototype to a future bike. I have spent the last year coming up with a design that I have intend to build and maybe in the future sell. However, whilst I can design frames on paper, I do need to learn cad to get dimensions and part files for cncing.
Active Contributor
oneloosecrank
Message 12 of 38 (245 Views)
10-06-2013 04:15 AM in reply to: oneloosecrank
I intend to be around cad for a while and will probably be asking lots of questions until I can produce independently. Sorry for double post, phone wouldn't let me edit the first.
*Expert Elite*
JDMather
Message 13 of 38 (239 Views)
10-06-2013 04:27 AM in reply to: oneloosecrank
If you are persistant the users here will help you for as long as it takes.
You did not include the part Main triangle.ipt in this thread.
I have an earlier part with that name, but Inventor does not see it as your current assembly part and I get constraint errors.
Can you attach your current Main triangle.ipt here.
I notice that most of your part sketches are not fully defined.
I recommend reading this
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Active Contributor
oneloosecrank
Message 14 of 38 (238 Views)
10-06-2013 04:31 AM in reply to: oneloosecrank
Ah OK, will do. I'll attach when I go in for lunch. I think this define sketches is causing me lots of issues - I'll need to study up on that. Cheers
Active Contributor
oneloosecrank
Message 15 of 38 (224 Views)
10-06-2013 06:51 AM in reply to: oneloosecrank
Triangle attached. The yoke might be needed as well now as I started on it this morning.
*Expert Elite*
JDMather
Message 16 of 38 (208 Views)
10-06-2013 10:03 AM in reply to: oneloosecrank
Once you learn how Inventor assigns assembly constraints - most of the work is done by Inventor for you automatically.
For example, by click, hold and drag a line off of an arc - the Tangent Constraint is added automatically.  By click, hold and drag off of a line endpoint (while still in the line command) an tangent arc can be created.
Zoom (way) in on the location in attached image.
What do you see?
Why you are fixing this - add tangents to your arcs and lines.
In order for me to manufacture something out on the shop floor - it should be fully defined.
So why shouldn't the designer do this work before sending to manufacturing?
*Expert Elite*
JDMather
Message 17 of 38 (205 Views)
10-06-2013 10:22 AM in reply to: JDMather
At your level of experience you should probably NOT be creating sketches at the assembly level.  (see attached image)
And probably not axis or workplanes.
If you want to define the locations of the tires/wheels relative to the frame, then create a sketch in the Main traingle.ipt file that you can then use in the assembly to constrain the tyre and rim.ipt.
I recommend that you start investigating multi-body solids (master modeling) techniques were you model all of the parts in a single part file (probably want to investigate Sketch Blocks as well - since you have relative motion) and then push out the individual parts and assembly when completed (or nearly completed).
I will try to post an example tomorrow if I get a chance.  In the meantime - you should concentrate on getting correct fully defined sketches.
For the 35t chainring - do you want a true sprocket?  If so - I can walk you through an interesting proceedure that will give you a rock-solid understanding of parametric constraints and dimensions.
Active Contributor
oneloosecrank
Message 18 of 38 (179 Views)
10-07-2013 09:54 AM in reply to: oneloosecrank
JDMather:
I agree, the designer should be creating designs fully useable by the manufacturer. Do you mean that, the sketch I've created isn't fully defined, and by this, the nodes aren't properly intersecting so it's just a birds nest of lines? I've noticed that sometimes when I'm placing lines they aren't connecting properly. I'll have to be careful with that.
JDMather:
Thanks, but the chainring is only there as a dimensional tool. The aim of this project is to create the yoke which you have used in your attached image. It has to connect to the lower linkages and spread around the tyre without contacting the chainring. Everything else is merely there for my own learning or to dimension the yoke. My short term goal is to have the lower linkages and the yoke CNCed to build a new rear end for a test mule. My long term aims are to understand Inventor enough to be able to CAD from the groud up my own prototype frame (twhich has already been designed). The future prototype depends on the success of the suspension kinematics of this test mule. Unfortunarely, it's the yoke is the one darn thing I can't get right at the moment! I'll go back through your post and seek out tutorials and further learning on the areas you have mentioned, in the meantime, have you any ideas why when I try to extrude that part (see attached) I can only make a cut, and not a solid?
*Expert Elite*
JDMather
Message 19 of 38 (175 Views)
10-07-2013 10:05 AM in reply to: oneloosecrank
oneloosecrank wrote:
..I can only make a cut, and not a solid?
Walk out to the shop floor (figuratively - in your mind).
You have an assembly before you.  You can only cut existing parts.  You cannot magically add material.
Your sketch is at the assembly level - therefore it will only allow you to cut.
You need to create parts at the part level.
For your design - the easiest way to do this would be multi-body solids techniques.
Are you willing to start this one over from scratch?
Right from the beginning?
If so, I can walk you through how I would do the design.
Active Contributor
oneloosecrank
Message 20 of 38 (164 Views)
10-07-2013 10:18 AM in reply to: JDMather
I see, if you are unable to add material in assembly then that explains a few things. I assumed that a new sketch would just start a new part - I did wonder why no new file was being created to go with that part...
And yes, I'm very willing to start over. There's a few dimensional short comings that I want to re-do as well. Advice on how better to approach project this is extremely welcome :smileyhappy:
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
