Inventor General
Active Member
aoliver-
Message 1 of 9 (1,232 Views)
array/pattern features with different dimensions for each instance
1232 Views, 8 Replies
09-19-2012 05:03 AM
I would like to generate a rectangular pattern of extruded tubes which have an internal radius that is proportional to the distance to the centre point of the pattern.  Or in other words tubes which are narrower in the centre, and wider at the exterior.  Is there a way to do this without resorting to creating each tube individually?
More generally, is there a way to parameterise a feature dimension/parameter so that it is a function of spatial position?
Many thanks,
Aaron
JDMather
Message 2 of 9 (1,227 Views)
Re: array/pattern features with different dimensions for each instance
09-19-2012 05:23 AM in reply to: aoliver-
Make the diameter dimension a function of the distance from origin of the pattern.
Can you attach an ipt here of what you have attempted so far?
Are you trying to do this a single part file or do you need as an assembly of parts?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Active Member
aoliver-
Message 3 of 9 (1,211 Views)
09-19-2012 06:02 AM in reply to: JDMather
This would be a single part file, ultimately I want to make a single 3D solid which I can use in CFD, and also 3D print the structural volume.  I'm trying to homogenise flow in a manifold basically by adjusting the orifice diameter
I haven't attempted anything yet, so nothing to attach. However, a simple example would consist of a circular disc axially along z, 100mm diameter, 3mm thick.  A sketch would then be created on one face, and a 2mm circle drawn at the centre.  That would then be extruded (say 50mm), and then patterned isotropically in the x and y directions across the face, creating a 9x9 array of cylinders, with spacing 10mm.  I would like to be able to adjust the extruded cylinder diameter according to the radial position of each cylinder (so square root of x^2 + y^2) with respect to the origin.
Valued Mentor
mpatchus
Message 4 of 9 (1,205 Views)
09-19-2012 06:33 AM in reply to: aoliver-
This sounds like a task begging for iLogic.
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
JDMather
Message 5 of 9 (1,203 Views)
09-19-2012 06:37 AM in reply to: aoliver-
I think you should make the first attempt before anyone else.
Active Member
aoliver-
Message 6 of 9 (1,194 Views)
09-19-2012 06:57 AM in reply to: JDMather
ok, here you go.  It's just a simple array of the cylinders though, I have no idea, barring manually creating each cylinder from its own sketched circle, how to change the radius of each cylinder based on its radial distance from the origin.
Valued Contributor
nannerdw
Message 7 of 9 (1,169 Views)
09-19-2012 07:56 AM in reply to: aoliver-
If it's just 9x9, it shouldn't be too much work to set it up with a geometric construction, using an angled line tangent to a row of circles to drive their diameters.  You only have to draw 1/4 of the circles, and then do a 4x circular pattern around the center.
Something like this:
It takes a while to set up, but with this method it should be easy to make quick changes to your parameters by adjusting the angle of the tangent line.
-Using Autodesk Inventor Professional 2012
Active Member
aoliver-
Message 8 of 9 (1,152 Views)
09-19-2012 08:18 AM in reply to: nannerdw
That's pretty neat, thanks!
What about non-linear grading of sizes?  For example so that they change by a square law - can a curve be defined by an equation?
Valued Contributor
nannerdw
Message 9 of 9 (1,149 Views)
09-19-2012 08:28 AM in reply to: aoliver-
IV 2013 has equation curves.  If you end up using an equation curve and require the diameters to exactly follow your non-linear scaling equation, just remember that the curve will have to pass through each circle at the same location. (eg. at the top point on each circle, rather than tangent to each circle.)
If you're using an older version of IV and don't need the non-linear scaling to be 100% accurate, you can approximate it with a spline.
CBliss has a couple of examples on his site for quadratic and sine curves.
Look at the bottom of this page:
http://cbliss.com/inventor/iFeatures/index.htm
If you're using an older version of IV and require 100% accuracy, you'll have to replace the tangent line with a set of parameters defined by functions, which could get a pretty tedious.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
