Until you mentioned it the other day, I never noticed that the pattern
overlapped itself. I just assumed it wouldn't create thos instances when the
directions were parralell. Now that I realize how it works, I'll definitely
use 2 5x1 arrays.
It would be nice to see a check box added to the array window that would
eliminate overlapping instances, or just create instances along the
direction axis. Creating two arrays in this case makes the part harder to
manage.
"Tom Sturtevant (Autodesk)" wrote in message
news:40f84bf2_3@newsprd01...
> Hi Kevin,
> I understand your point - the patterns with and without the nested mirror
> are very similar, why does one generate an error but not the other? The
> answer is that Inventor handles patterns of features (e.g. pattern of
Hole)
> differently than patterns of patterns (e.g. your pattern containing the
> Mirror). I'm not trying to defend how Inventor does it (well, OK, I am
> doing that a little). At a minimum it is inconsistent.
> In order to compute your 5x5 pattern of the mirror, Inventor basically
> recomputes the mirror in 24 different locations. All but 8 of these
overlap
> a previous occurrence, and errors get generated because the part did not
get
> modified. When the other features are patterned, we can use a more
> optimized approach which doesn't warn about the overlapping occurrences.
> Again, I really recommend that you model this as two 5x1 patterns. This
> will give you a smaller, faster, more stable part.
> Tom Sturtevant
> Inventor Part Modeling
> "Kevin Wehner" wrote in message
> news:40f8208c$1_2@newsprd01...
> > That doesn't make sense to me, because I only get the error when
arraying
> > the mirror. There are also ovelapping occurrences of the hole patterns.
> > news:40f80ebb$1_2@newsprd01...
> > > Hi Kevin,
> > > The problem is that the way the Rectangular Patterns are defined you
end
> > up
> > > with multiple overlapping occurrences. Rectangular Pattern1 is 5x5
with
> > > direction2 parallel and opposite to direction1. Inventor computes 25
> > > occurrences, but only 9 of those are unique - the overlapping
> occurrences
> > > complain because the nested mirror did not have any affect on the
part.
> > If
> > > you expand the pattern in the browser and highlight the occurrences
> > > individually you'll understand what's going on.
> > > I think the best way to create a bi-directional "centered" pattern
like
> > that
> > > is with two separate patterns - i.e. a 1x5 for each direction.
> > > Hope that helps.
> > > Tom Sturtevant
> > > news:40f7cf58_3@newsprd01...
> > > > Can someone explain why I get the errors in 'with mirror.ipt'? It
has
> to
> > > do
> > > > with the mirror feature in the arrays, but I don't understand
exactly
> > what
> > > > the problem is.
