Hello I want to animate this cog wheel so that it rotate, how do I do?
Hi!
You can Study a bit, see some youtube videos and try to do it.
If you will have questions about it, post here what you already attempt and we will guide you.
For starting, you can use the Motion constrain and try to achieve what you want.
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
You are in a Weldment assembly - a weldment does not have motion.
You have too many constraints on the wheel.
You will need to create a new standard assembly.
Experiment with the Rotational/Translation assembly constraint (see the Arbor Press tutorial assembly).
The CADWhisperer YouTube Channel
