example attached of 4 regulators and an air feed pipe.The example picture shows where i need to run 4 air hoses.In an assembly how would i place the air hoses between the regulators and the air post?
This is just a small segment of a large assembly file as there will be many air hoses of varying lengths ..is this best done with Pipe & Route ?
Regards
IJC
If you have Routed Systems, of course use that.
Otherwise start a new part in the assembly and Project Geometry connection points, then use Spline and Sweep.
Lets see.. you have some tubing/hose to route... Yes I'd say the tube/pipe routing addin would be the correct choice.
Something like this?
Blair:
Showoff!
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Not nearly as impressive.....
Chris Benner
A simple hydraulic lay-out for a customer
