Inventor General
Active Contributor
sam__gleeson
Message 1 of 10 (333 Views)
agitator
333 Views, 9 Replies
12-11-2012 04:23 AM
I am after a agitator part if anyone have available.This goes on a shaft driven  by a electrical motor.
Sam
JDMather
Message 2 of 10 (322 Views)
Re: agitator
12-11-2012 05:18 AM in reply to: sam__gleeson
Post screen shot or url of similar part.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Valued Mentor
mpatchus
Message 3 of 10 (293 Views)
Re: agitator
12-11-2012 10:39 AM in reply to: sam__gleeson
Here's a real quick one I made up.
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
Active Contributor
sam__gleeson
Message 4 of 10 (260 Views)
Re: agitator
12-12-2012 03:36 AM in reply to: sam__gleeson
Thanks Mike
Here is a picture JD of a agitator
Best Regards
Sam
Valued Mentor
mpatchus
Message 5 of 10 (250 Views)
Re: agitator
12-12-2012 04:17 AM in reply to: sam__gleeson
Oh THAT kind of agitator!   LOL
Mike Patchus
Active Contributor
sam__gleeson
Message 6 of 10 (243 Views)
Re: agitator
12-12-2012 04:33 AM in reply to: mpatchus
Very nice Mike...that was quick...do you have something similiar where the blades are egg shape instead of the straight blades
Appreciated
Sam
Valued Mentor
mpatchus
Message 7 of 10 (238 Views)
Re: agitator
12-12-2012 04:59 AM in reply to: sam__gleeson
Sure, just used the same part and changed the way the LOFT is created.
Mike Patchus
Active Contributor
sam__gleeson
Message 8 of 10 (236 Views)
Re: agitator
12-12-2012 05:02 AM in reply to: sam__gleeson
Hi Mike
fantastic...thanks for the models...i will now practice
Best Regards
Sam
Valued Mentor
mpatchus
Message 9 of 10 (226 Views)
Re: agitator
12-12-2012 05:07 AM in reply to: sam__gleeson
The straight bladed vane was created with two lofts.  One for the blade using two sketches for the blade profile, and another to connect the blade base to the hub, also using two sketches/profiles.
The curved bladed vane was created with one loft using the three sketches. I also added a fillet to round the end of the blade.
That's the only real difference.  If you compare the two part files you can see the process.  You can tweak the dimensions as required to achieve different results.
Mike Patchus
Active Contributor
sam__gleeson
Message 10 of 10 (219 Views)
Re: agitator
12-12-2012 05:17 AM in reply to: mpatchus
Thanks Mike...very helpful
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
