Inventor General
Valued Contributor
Message 1 of 9 (248 Views)
Accepted Solution
adding color
248 Views, 8 Replies
10-06-2012 02:50 PM
I have some shapes in which i want to add solid color to sections.I cannot find anywhere to accomplish this effect.Can this be done in Inventor 2013..it will be a 2D view
Please view the attached 2013 file...can this be done
Rich
*Expert Elite*
Message 2 of 9 (239 Views)
Re: adding color
10-06-2012 04:49 PM in reply to: richard_cirillo
If it is 2D - why aren't you creating the sketch in idw or dwg?
http://forums.autodesk.com/t5/AutoCAD-2013/symbols/td-p/3649346
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Valued Contributor
Message 3 of 9 (228 Views)
Re: adding color
10-06-2012 06:34 PM in reply to: JDMather
I use Inventor much more then Autocad (new) so if possible would rat5her do in Inventor
Rich
*Expert Elite*
Message 4 of 9 (210 Views)
Re: adding color
10-07-2012 04:43 AM in reply to: richard_cirillo
If it is 2D - why aren't you creating the sketch in Inventor idw or Inventor dwg?
Sketched Symbols might be the way to go.
Valued Contributor
Message 5 of 9 (202 Views)
Re: adding color
10-07-2012 05:02 AM in reply to: richard_cirillo
Thanks..
Yes you are correct....can the title block be removed from the bottom right hand corner
Rich
*Expert Elite*
Message 6 of 9 (199 Views)
Re: adding color
10-07-2012 05:15 AM in reply to: richard_cirillo
Yes.
Right mouse button in browser.
Valued Contributor
Message 7 of 9 (196 Views)
Re: adding color
10-07-2012 05:19 AM in reply to: JDMather
JD Thank you
1 final question....can the shapes be filled in with solid colors
Rich
*Expert Elite*
Message 8 of 9 (194 Views)
Re: adding color
10-07-2012 05:22 AM in reply to: richard_cirillo
Yes.
Hatch/Color Fill.   (Fill/Hatch Region)
....and why do I doubt this is the final question?   :smileysurprised:
Valued Contributor
Message 9 of 9 (190 Views)
Re: adding color
10-07-2012 05:25 AM in reply to: JDMather
It is as i also just found it
Rich
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
