Inventor General
Valued Contributor
Message 1 of 8 (250 Views)
adding chains
250 Views, 7 Replies
09-11-2012 05:42 AM
Hi
I started to model up a lifting cradle but do not know how to progress further.I attached a 2013 version of model done so far.How can i place 4 chains on the top bracket to a ring?
Regards
Rich
*Pro
jletcher
Message 2 of 8 (237 Views)
Re: adding chains
09-11-2012 06:09 AM in reply to: richard_cirillo
Well you can try and use my chain here is the fies you can change the chain to the size you need and the chain links move together..
Just make it adaptive in your assembly
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
Valued Contributor
Message 3 of 8 (225 Views)
Re: adding chains
09-11-2012 06:23 AM in reply to: jletcher
Hi Jletcher
Thanks for files..I`m sorry but i am beginner here but that is very good.I see it moves in assembly.What is way to mate to both top bracket and large chain ring?What is technique to use please?
Cam more links be added to your chain?
Thanks again
Rich
*Pro
jletcher
Message 4 of 8 (216 Views)
Re: adding chains
09-11-2012 06:51 AM in reply to: richard_cirillo
Yes you can add as many links as you wish just copy how I did it.
as far as linking to your assembly you can do it in the same manner just add work point to your link as far as the base I would use an eyebolt to connect the chain to.
James Letcher
Valued Contributor
Message 5 of 8 (210 Views)
Re: adding chains
09-11-2012 07:00 AM in reply to: jletcher
Thanks jletcher,,,the chain is excellent
Rich
Valued Contributor
Message 6 of 8 (190 Views)
Re: adding chains
09-11-2012 08:15 AM in reply to: richard_cirillo
What is the way to fit a hinge to one side of the bracket....would i need to make a hinge separately or would you make at the part level....how would i make the hinge?
Regards
Rich
*Pro
jletcher
Message 7 of 8 (181 Views)
Re: adding chains
09-11-2012 08:33 AM in reply to: richard_cirillo
Hinge ?
James Letcher
Valued Contributor
Message 8 of 8 (131 Views)
Re: adding chains
09-12-2012 02:05 AM in reply to: richard_cirillo
I want to be able to place a hinge on 1 side so as to open the bracket and a latch on the other side to keep the bracket closed
Regards
Rich
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
