Inventor Forum
adding chains
7 REPLIES 7
Message 1 of 8
richard_cirillo
589 Views, 7 Replies
adding chains
Hi
I started to model up a lifting cradle but do not know how to progress further.I attached a 2013 version of model done so far.How can i place 4 chains on the top bracket to a ring?
Regards
Rich
7 REPLIES 7
Message 2 of 8
jletcher
in reply to: richard_cirillo
Well you can try and use my chain here is the fies you can change the chain to the size you need and the chain links move together..
Just make it adaptive in your assembly
Message 3 of 8
richard_cirillo
in reply to: jletcher
Hi Jletcher
Thanks for files..I`m sorry but i am beginner here but that is very good.I see it moves in assembly.What is way to mate to both top bracket and large chain ring?What is technique to use please?
Cam more links be added to your chain?
Thanks again
Rich
Message 4 of 8
jletcher
Yes you can add as many links as you wish just copy how I did it.
as far as linking to your assembly you can do it in the same manner just add work point to your link as far as the base I would use an eyebolt to connect the chain to.
Message 5 of 8
richard_cirillo
Thanks jletcher,,,the chain is excellent
Rich
Message 6 of 8
What is the way to fit a hinge to one side of the bracket....would i need to make a hinge separately or would you make at the part level....how would i make the hinge?
Regards
Rich
Message 7 of 8
jletcher
Hinge ?
Message 8 of 8
I want to be able to place a hinge on 1 side so as to open the bracket and a latch on the other side to keep the bracket closed
Regards
Rich
