Inventor General
Active Member
Message 1 of 3 (193 Views)
Zoom in Inventor as compared to 2D AutoCAD
193 Views, 2 Replies
08-29-2012 08:42 AM
Zoom . . .
When I use AutoCAD Inventor:
* Rolling the mouse wheel toward me, the object zooms larger, and
* Rolling the mouse wheel away from my body, the object zooms smaller.
Just the opposite, when I use good ole' 2D AutoCAD and AutoCAD Electrical:
* Rolling the mouse wheel toward me, the object zooms smaller, and
* Rolling the mouse wheel away from my body, the object zooms larger.
Is it possible to change the zoom function in 2D AutoCAD and AutoCAD Electrical to operate in the same fashion as in Inventor . . .
* Or will this lead to further melting of the polar ice caps!
Thanking you in advance, I am,
CADManTom
*Pro
jletcher
Message 2 of 3 (188 Views)
Re: Zoom in Inventor as compared to 2D AutoCAD
08-29-2012 08:44 AM in reply to: cadmantom
  1. On the Tools menu, click Options.
  2. On the 3D Modelling tab, under 3D Navigation, select Reverse Mouse wheel zoom.
Method 2
  1. On the AutoCAD command line, enter ZOOMWHEEL.
  2. Enter 0 to use the mouse wheel as in previous AutoCAD releases (moving the wheel up zooms in, moving down zooms out).
  3. Enter 1 to reverse the mouse wheel direction (moving the wheel up zooms out, moving down zooms in).
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
Active Member
Message 3 of 3 (176 Views)
08-29-2012 09:06 AM in reply to: jletcher
Thanks!  This works completely as described!
Best of wishes,
CADManTom
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
