Inventor Forum
XDIM YDIM Hole table issue
2 REPLIES 2
spoine
511 Views, 2 Replies
Hello
I have found a problem with creating a hole table which I hope could be solved.
It seems when creating a hole table in a drawing (hole table - view option) the XDIM and YDIM are opposite
to the X and Y ucs icon in the model.
(please see attached image)
An easy fix is to edit the hole table and change the text in the column settings.
Just wandering if there is a setting that needs to be done to rectify this.
Cheers
IVSuite 2010
Spoine
3D Modeling
Product Design
Windows 7 Professional x64
Dell Precision T3500
2.80 GHz Xeon 12 GB RAM
Quadro FX 1800
2 REPLIES 2
pcunningham1
in reply to: spoine
1. The hole table coordinate table is based, as it should be, on the drawing view, not on any ucs in the drawings.
2. In your picture on the right, why do you have the upper left quad labeled 'X, -Y'. It should be '-X, Y'. Same with lower right quad. (Unless I'm missing something)
Paul Cunningham
IV2008
Paul Cunningham
IV2008
in reply to: spoine
To further Pauls post, the co-ordinates are based on the location of the
"Target" origin point (litle circle with black/white quadrants).
IV2010-Pro-sp2 Subscript-Pac
Vista Business 64bit Sp2
Core i7 950 @ 3.07Ghz EVGA x58 Classified
12Gb DDR3-1600, 240Gb (4 x 60 Gb SSD - RAID0)
Quadro FX3800 - 191.87
SpacePilot 3.8.3 / 6.8.1
AVG9.0
"spoine" wrote in message news:6351928@discussion.autodesk.com...
Hello
solved.
settings.
Cheers
IVSuite 2010
