Having created a series of xref,s and needed to reload them into the drawing i find that the lines,dimensions etc are coming in as a greyscale type of linetype.
The original xrefs are fine with the correct lineweights,colours etc,so what is happening.
The drawings and xrefs are in autocad 2010 format,although it is possible that the original x ref.s were created in 2008 format.
Any suggestions please.
Regards
Solved by JDMather. Go to Solution.
Is this an AutoCAD dwg question or an Inventor dwg question?
Can you attach example here?
The CADWhisperer YouTube Channel
