Inventor Forum
Wrap around cover
4 REPLIES 4
mnielsen55
334 Views, 4 Replies
Wrap around cover
Hey guys, I'm trying to design a cover that will wrap around two housing halves to cover the seam (similar to a cell phone cover).
I've attached the model that I've got so far... I was trying to do a sweep around the housing, but I'm not quite sure how to get the end result I'm looking for. If you look at the sketches you'll have a good idea of how I was trying to achieve, but I'm not sure if I can just do a sweep with multiple profiles as the shape changes around the housing, or if I have to do it some other way.
Thanks for any help you can provide!
-Mark
4 REPLIES 4
JavaLodge
in reply to: mnielsen55
When I opened your file I got a error message for a missing link, the file HOUSING HALVES.iam. Does this file contain the sketches? I'm not sure where you want to go with this. Maybe if you could draw a picture of what you need. Also it would help to post your Inventor version.
____________________________________________________________
Slow is good and good is fast.
mnielsen55
in reply to: JavaLodge
Sorry about that. It was a derived part from an assembly. Here are the missing files.
The files are from Inventor Pro 2014.
-Mark
JDMather
I probably would have done all of the parts (including the cover) in one part file as multi-body solids but you can still do it the way you are.
But I would have Derived Component the parts as Composite Surface bodies and then Thicken the surfaces to get the cover.
Not sure where you were going to go regarding top/bottom but see second attachment.
mnielsen55
in reply to: JDMather
The two housing halves don't match up exactly (sloppy sketching on my part), but I plan on doing a thicken to join the two halves. The model you did is very helpful. I'll see if I can get it cleaned up enough to use.
Thanks!
-Mark
