Hi All
I've seen in the Whats new for Inventor 2013 and also in the wikihelp that you can merge your cores and cavities into your mold base plates.
I now have got to a point where I want to do this but when I select Workpiece Pocket I do not get the option to "Merge Cores and Cavities into Moldbase Plates". Are there specific contions for this to happen? How do I know if my mold design meets these conditions?
I have attached a few screen shots for clarification.
If more information is need I can supply it. Please can someone help me with this.
The problem is that you have combined the Cores and Cavities before you merge the Core/Cavity to Mold Base plates.
We don't support combined Core and Cavity to be merged into Mold Base plates. This is the reason.
I hope this helps.
Yes, you should delete the combined core and cavity feature to use Merge the Core/Cavity to Mold Base plates option in Workpiece Pocket. You may need to adjust the dimensions of workpiece to meet your requirement.
