Inventor Forum
Working with imported STEP file. Solid Base to saparate parts?
7 REPLIES 7
Message 1 of 8
EngineerMickeyMouse
495 Views, 7 Replies
Model in STEP file was delivered to me and it seems it could be made in Inventor earlier, nevertheless after opening and saving in Inventor 2014 it loads as a one big part and I can see many solid bases in model tree. Is there any option to save these solid bases as a separate parts?
7 REPLIES 7
Message 2 of 8
Yes - you can use the Make Components command, (from Manage tab) to push each body out to an individual part file. An assembly is also created which reference each component in its' correct location. You may also be able to change the Step import option so that the assembly data in the step file is imported as individual parts initially. Hope this helps, Chris
Chris Mitchell
PDMS Customer Engagment Team
Autodesk, Inc.
Message 3 of 8
in reply to: ChrisMitchell01
IS THERE A WAY TO USE THAT BASE FILE OR CHANGE IT?  SO I CAN FLATTEN OUT A SHEET METAL PART
Message 4 of 8
TheCADWhisperer
Yes, attach the file here and someone will demonstrate how to create the Flat Pattern.
Message 5 of 8
in reply to: TheCADWhisperer
HERE IS THE BASE FILE THAT WAS PULLED FROM A STEP ASSEMBLY.
Message 6 of 8
Rob67ert
Just open the file.
In Sheet Metal Defaults change Thickness to the thickness of the part (4.826mm)
And then Create Flat Pattern.
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
Message 7 of 8
in reply to: Rob67ert
WOW!  THIS IS GREAT
THANKS!!
Message 8 of 8
SO SIMPLE.  I THOUGHT THE WARNING SAYING ABOUT THE THICKNESS WAS TELLING ME I COULDN'T PROCEED.  JUST A WARNING.  THANKS
ALSO THE MAKING COMPONENTS EARLIER IN THIS THREAD HELPED.
THANKS
