I'm using inventor studio for the first time(Inventor 2014 / Windows 7). I'm having some trouble with work surfaces showing up in my rendering. The surfces are set with the visibility turned off. When I'm in my normal assembly window, they're invisible. They're even invisible while im in studio, setting up lights & such. They only show up on my renders. If i go into each part and suppress them they render ok. Problem is I have sketch geometry and constraints that crash when they're supressed, so I really need them as active, but invisible.
Any suggestions?
Have you installed Service Pack 1?
Video card driver up-to-date?
Does the behavior persist after reboot?
Installed sp1, still having the same problem. Attached is an example of the issue. If you look in the toe area of the cabinetry in the image, you see my work surface as visible. It only shows up in my rendering. looking at the active model, the visibility is turned off and you can't see the surface.
