Inventor Forum
Work Plane in an Assembly iam
9 REPLIES 9
Message 1 of 10
533 Views, 9 Replies
I put in a Work Plane in an Assembly. After constraining to that workplane
I would like to turn off this plane. I cannot highlight it by clicking on
it and I cannot find it in the model browser. How do you turn it off????
Ole Germer
Helping create better involute profiles for gears
http://www.geocities.com/olegermer/index.html
9 REPLIES 9
Message 2 of 10
It has to be somewhere in your browser.
Try to expand all children in your browser, look for a work plane that is not grayed out, select that one and turn off the visibility.
Message 3 of 10
In the assy, set your selection priority to feature or faces/edges, then
select on screen and shut off visibility. While your there you may as well
do a find in browser to see why you couldn't see it there before.
- Drew
Drew Fulford, B.A.Sc. Systems Engineer
Solid Caddgroup Inc, Burlington, Ontario
Phone: (905) 331-9670 Fax: (905) 331-7280
Member of the Autodesk Discussion Forum Moderator Program
Check out my MDT & Inventor FAQ @ http://www.mymcad.com/
"Ole Germer" wrote in message
news:EE0869CC0D37C2A9EF945CDEA7D1CBF0@in.WebX.maYIadrTaRb...
workplane
> Ole Germer
Message 4 of 10
Is there a good up to date tutorial on work planes? I have a demo
version of Inventor and I'm having the hardest time with work planes.
I want to make a plane on the center of a circular feature and can
only find how to make it tangent to the feature not on center.
Thanks, Rich
workplane
clicking on
off????
> Ole Germer
Message 5 of 10
The obvious answer.  Select  features
from the little pull down beside the redo icon.  Now I can turn off the
visibility.  I still cannot find that work plane in the
browser!
Ole
It
Message 6 of 10
Ole,
Switch to Feature priority and RMB->Find in Browser on the workplane in
the model window.
This is real nice in that it will open origin folders and expand subs if
it needs to.
QBZ
news:60E7D13ADDD207BF2AB0622DF15A3494@in.WebX.maYIadrTaRb...
> The obvious answer. Select features from the little pull down beside
the redo icon. Now I can turn off the visibility. I still cannot find
that work plane in the browser!
> Ole
> "FRANKF" wrote in message
news:f1274ac.0@WebX.maYIadrTaRb...
Message 7 of 10
I think an axis (axis tool/OD of cyl) should give you a workfeature to make
a plane by picking the axis on the part and an origin workplane from the
browser. You should be able to make it whatever angle you want from there.
~Larry
"Rich B" wrote in message
news:17A66F96F876DACBEF3FDE2469B9C681@in.WebX.maYIadrTaRb...
> Thanks, Rich
> workplane
> clicking on
> off????
> > Ole Germer
Message 8 of 10
At the top of the browser is a upside down dunce hat. Press it and there is
a choice
Hide work features
Hide notes
Hide Documents
Hide Warnings
This is new to R6
Ole
"Drew Fulford" wrote in message
news:0DEBAAAFE7382667DB98B95E96B3722A@in.WebX.maYIadrTaRb...
> - Drew
> workplane
on
off????
> > Ole Germer
Message 9 of 10
SveinE
Hi.
Yust wanted to say that this is not new too R6. I have R5 and R6 installed and it`s in both. I`m using it frequently.
Regards Svein
Message 10 of 10
Under the view menu is there not an option to hide work planes now.
View/Object Visibility
Kathy Johnson
news:D697A805F7A50E3994818536CC677CE3@in.WebX.maYIadrTaRb...
is
> a choice
> Hide work features
> Hide notes
> Hide Documents
> Hide Warnings
> This is new to R6
> Ole
well
> > - Drew
> > workplane
clicking
> on
> off????
> > > Ole Germer
