Inventor General
New Member
13088
Message 1 of 5 (530 Views)
Wood Carving
530 Views, 4 Replies
01-24-2013 10:02 AM
Hi I am a highschool student and last year I started a Gothic style throne chair in a woodworking class. I first drew it up in Autodesk Inventor and then created job plan sheets for each individual part. This semester I plan to finish the throne. I want to incorporate gothic themed carvings (designed by me) into the throne. Our school owns a 3D Router so my plan was to create the 3D carvings and have the router cut them into parts of my throne. My question is what software I should use to create the carvings. Should I use Inventor?
-Roy
blair
Message 2 of 5 (509 Views)
Re: Wood Carving
01-24-2013 12:28 PM in reply to: 13088
If you have already modeled everthing in Inventor, all the pieces for the assembly, the next logical step would be to use the IPT's and import them into the CAM software for the NC 3D router.
IV2015 up1 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
PaulMunford
Message 3 of 5 (506 Views)
Re: Wood Carving
01-24-2013 12:35 PM in reply to: blair
You will want solid geometry for your CAM programming. This can be done in Inventor - see this film:
http://youtu.be/awXh8Svs9nE
You could use Fusion, 123D or AutoCAD - but you wouldn't maintain the parametric relationship with your inventor IPTs.
The CAD Setter Out Blog @CadSetterOut
Inventor Surfacing | AutoCAD | CAD Standards
Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
Curtis_Waguespack
Message 4 of 5 (487 Views)
Re: Wood Carving
01-24-2013 01:15 PM in reply to: 13088
Hi 13088,
As a student I think you will learn a great deal in terms of technique by modeling some of the carvings in Inventor. But if you were to pursue this professionally or even as a serious hobby, you would want to be aware of other software that is dedicated to the CNC woodcarving industry, such as these examples:
http://www.vectric.com/WebSite/Vectric/vcp/vcp_index.htm
http://www.carve3d.com/index.asp?pageID=6
http://www.vectorart3d.com/
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
New Member
13088
Message 5 of 5 (465 Views)
Re: Wood Carving
01-24-2013 04:32 PM in reply to: Curtis_Waguespack
Thanks a lot for all of your replys. The software the router uses is Cut3D which I believe is a product from Vectric. I will look more into this.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
