Whenever I try and extrude or embross my buisness Logo I get the error "The attempted operation did not produce a meaningful result"
I have attached file and was hoping somebody would have the tim to try and se the logo into the puck with better results.
Bryce Flug
I would remodel from scratch in Inventor - the design is not complicated.
In fact, the portion of the sketch that is giving trouble is simply a parallelogram with filleted corners.
The entire file size is much larger than it needs to be if done all with native Inventor geometry.
Drag down EOP in attached.
I redrew it and it worked fine, but i seem to have nothing but trouble when importing illustrator files that have been exported as dwg's. Is there a better way that I should be going about vecor wrapping my amiages for use in inventor?
Also its Inventor 2013 Professional
Bryce
