Inventor Forum
Wont Extrude Dwg (cant find answer in forum)
3 REPLIES 3
fluggie22
957 Views, 3 Replies
Whenever I try and extrude or embross my buisness Logo I get the error  "The attempted operation did not produce a meaningful result"
I have attached file and was hoping somebody would have the tim to try and se the logo into the puck with better results.
Bryce Flug
3 REPLIES 3
JDMather
in reply to: fluggie22
I would remodel from scratch in Inventor - the design is not complicated.
In fact, the portion of the sketch that is giving trouble is simply a parallelogram with filleted corners.
The entire file size is much larger than it needs to be if done all with native Inventor geometry.
Drag down EOP in attached.
swordmaster
what version of Inventor?
Inventor 2010 Certified Professional
fluggie22
in reply to: JDMather
I redrew it and it worked fine, but i seem to have nothing but trouble when importing illustrator files that have been exported as dwg's. Is there a better way that I should be going about vecor wrapping my amiages for use in inventor?
Also its Inventor 2013 Professional
Bryce
