Inventor General
New Member
fluggie22
Message 1 of 4 (402 Views)
Wont Extrude Dwg (cant find answer in forum)
402 Views, 3 Replies
09-26-2012 11:22 AM
Whenever I try and extrude or embross my buisness Logo I get the error  "The attempted operation did not produce a meaningful result"
I have attached file and was hoping somebody would have the tim to try and se the logo into the puck with better results.
Bryce Flug
JDMather
Message 2 of 4 (394 Views)
Re: Wont Extrude Dwg (cant find answer in forum)
09-26-2012 11:39 AM in reply to: fluggie22
I would remodel from scratch in Inventor - the design is not complicated.
In fact, the portion of the sketch that is giving trouble is simply a parallelogram with filleted corners.
The entire file size is much larger than it needs to be if done all with native Inventor geometry.
Drag down EOP in attached.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Distinguished Mentor
swordmaster
Message 3 of 4 (392 Views)
09-26-2012 11:40 AM in reply to: fluggie22
what version of Inventor?
Inventor 2010 Certified Professional
New Member
fluggie22
Message 4 of 4 (387 Views)
09-26-2012 11:47 AM in reply to: JDMather
I redrew it and it worked fine, but i seem to have nothing but trouble when importing illustrator files that have been exported as dwg's. Is there a better way that I should be going about vecor wrapping my amiages for use in inventor?
Also its Inventor 2013 Professional
Bryce
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
