Inventor Forum
Wire routing
1 REPLY 1
G.Manikandan
160 Views, 1 Reply
Wire routing
Dear all,
I have doubts in wire routing .I hope that you can solve my problem. Doubts are listed below,
1.How to make wiring drawing in inventor
2.In bill of materials, i need wire lengths,dia,color.how can i add these things in bill of materials.
3.while taking bill of materials only harness is coming.I need each segments list .HOW CAN GET SEGMENTS LIST?
4.wiring details aslo ,I need.
Please provide guidelines to me with examples.
I am looking forward your reply immediately.
if you give reply for me .It will greatly help.
G.Manikandan
1 REPLY 1
in reply to: G.Manikandan
See my answers below.
Wei Li (AIPQA)
дÈëÏûÏ¢ÐÂÎÅ:4889454@discussion.autodesk.com...
Dear all,
[WEI: If you need a Nailboard drawing, you can use the Nailboard command
provided in the "Cable &Harness" panel;
If you need a normal view of the harness, you can create a base view of it
(normally you should create a base view of the top assembly of the harness),
then right click the harness assembly node from the browser and select
"Include Centerlines -> Wires/Cables".]
[WEI: For the above three questions, you can use the "Report" command.
Currently BOM doesn't support wires or segments. We provide several cfg
files under the "\Cable & Harness\Samples\Report Generator\" folder, such as
"Wire Run List.cfg" and "Segment Table.cfg". You can use them to create csv
files in report generator. If you would like the include them in your
Nailboard, you can use "Table" command to insert these csv files in the
Nailboard drawing.]
G.Manikandan
