Inventor Forum
Windows 8.1 Problems
34 REPLIES 34
Message 1 of 35
Talayoe
756 Views, 34 Replies
Hello all,
Am I the only one out there that is experiencing issues with Inventor Pro 2014 and Windows 8.1?
Specifically that at random times when you start a new document, or go to load a document, of any of the major file types (IAM, IPT, IDW) that inventor gets to the point where on the bottom of the screen it says 'Loading Presentation...' and then just never responds again??? I delt with it for a while, but it is really starting to grate on me now... I am typically now in the habbit of hitting save before I start or open any other document but I didnt today and lost a lot of work on a large assembly.
Its quite frusterating.
Anyone else experiencing this same issue? I would love to hear from you. Or maybe you have fixed this issue? Even better!
-Randy
Inventor 2017 PDS
34 REPLIES 34
Message 21 of 35
graeme.robinson
in reply to: blair
Afternoon
Changed to SP2 and still occurs
Graeme
Message 22 of 35
Graeme,
Please provide me withthe DxDiag information.
Thank you.
Bob Holland
Autodesk Product Support
Message 23 of 35
Hello
what is dxdiag? and how do I supply it
Graeme
Message 24 of 35
Greame,
The instructions were attached earlier in the thread.
Sorry.
I have attached them here.
Thank you.
Bob Holland
Message 25 of 35
As requested
Message 26 of 35
Graeme,
I expect that your Dell has two video cards.
Which one to you have it configured to work with Inventor?
If you switch, does it make a difference?
Thank you.
Bob Holland
Message 27 of 35
It has a intel hd graphics 4000
and a Nvidia quadro KM4000M
I presume it uses the Nvidia one?
Im no hardware expert
Regards
Graeme
Message 28 of 35
blair
in reply to: graeme.robinson
It will use the Intel HD onboard by default (power saving feature), you will need to go to the Nvidia Control Panel and tell Nvidia to use it's card for Inventor. Just RMB on the screen to allow access to the Nvidia Control Panel.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 29 of 35
graeme.robinson
in reply to: blair
its using Nvidia...see attached
Graeme
Message 30 of 35
blair
From the Nvidia Control Panel . Help, what driver version does it show. Dell is notorious for shipping units with extremely old/first release drivers.
Delta Tau Chi ΔΤΧ
Message 31 of 35
graeme.robinson
in reply to: blair
attached as requested
Graeme
Message 32 of 35
blair
I would do a complete un-install of Inventor, then run something like cCleaner.com and use it's Registry clean tool to clean up the Windows Registry. Do a system reboot, run the cCleaner again to clean up the Windows Registry, reboot, install Inventor. Make sure you are logged in as Administrator and have the UAC slider set to it's lowest position and install Inventor along with all Service Packs and Hotfixes.
Delta Tau Chi ΔΤΧ
Message 33 of 35
graeme.robinson
in reply to: blair
Ok
Thats a job for the weekend when I have no work, so will give it a try then
This install of 2014 was carried out after windows was upgraded to 8.1 as I was using 2013 which obviously didnt work when I went to 8.1, even though the compatibility checker didnt see this
Will let you know how I get on
Graeme
Message 34 of 35
Graeme,
Please update both of the video card drivers to the latest perfomance for each of the manufacturers.
Intel:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24593
Nvidia:
http://www.nvidia.com/download/driverResults.aspx/82064/en-us
Thank you.
Bob Holland
Message 35 of 35
I flattened the laptop and took it back to windows 8 and everything is good again
Im avoiding 8.1 as that seemed to be the issue
thanks
Graeme
