Inventor General
Member
Message 1 of 7 (506 Views)
Accepted Solution
Windows 8.1 Accessing Content Center on Inventor 2014
506 Views, 6 Replies
12-12-2013 12:20 PM
I have installed Inventor 2014 and Revit 2014 on to Windows 8.1 64 Bit.
The install went fine.
The only problem I have struck is that for instant if I create a new Assembly and want to open the Content Center from  Assemble - Place - Place from Content Center. Nothing happens when I go through this path way, there's no error, you know it's trying as the harddrive light is flashing away rapidly for a few minutes each time you ask for it to open.
What I have tired so far is to install service pack 1 and update 1 to service pack 1, neither have made a difference.
Any insight in how I can get this working would be appreciated. I know Windows 8.1 isn't officially supported by AutoDesk.
Cheers
Kent
Product Support
Message 2 of 7 (495 Views)
Re: Windows 8.1 Accessing Content Center on Inventor 2014
12-12-2013 01:37 PM in reply to: kent.champion
Kent,
Welcome to the Forum.
Can you please check and make sure that you have IDCL files in:
C:\ProgramData\Autodesk\Inventor 2014\Content Center\Libraries
Also please check your project file and make sure that this is where you have it pointing to.
These are the defaults.
If you have moved these items please make sure that all Project is seeing your Content Center libraries.
Thank you and we are looking forward to hearing back from you.
Bob Holland
Member
Message 3 of 7 (437 Views)
12-19-2013 05:08 PM in reply to: bob.holland
Sorry about the delay for the reply, sorry to say that the IDCL files are in the default location and the project file is pointing to the correct location.
I suspect it's something to with Windows 8.1 new folder\file permissions and the program itself doesn't have the authority to open the file to read.
Any other ideas or solutions out there are always welcomed.
Cheers
*Expert Elite*
blair
Message 4 of 7 (433 Views)
12-19-2013 05:29 PM in reply to: kent.champion
Try changing permissions, RMB on the Inventor icon to bring up the Properties and try using the Run as Administrator, also make sure the UAC slider is set to the lowest setting
IV2015 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
Member
Message 5 of 7 (367 Views)
01-16-2014 05:27 PM in reply to: blair
Sorry no good running as admin, our staff are all administartors of their machines and the UAC is disabled by default, the content center files aer in the correct location, it just seems that they can't be read.
Inventor 2014 on Windows 7 has no problems accessing the files, so I am certain it's a Windows 8.1 file permission issue that Inventor 2014 isn't able to read the files.
Cheers for the input tho.
*Expert Elite*
blair
Message 6 of 7 (346 Views)
01-17-2014 09:01 AM in reply to: kent.champion
Try installing the latest SP's from Autodesk, one was just released last week.
Win7-64
Member
Message 7 of 7 (332 Views)
01-17-2014 10:34 PM in reply to: blair
Hi Blair,
I had installed Service Pack 1 and Update 1 to Service Pack 1, neither them made a difference, but the latest one Update 2 for Inventor 2014 Service Pack 1 solved my problem.
In the release notes they addressed the issue where Content Center doesn't work with roaming profiles in Inventor 2014, I suspect that this was my problem as our staff have roaming profiles.
Thanks for letting me know about the latest update release, I check for updates at the start and middle of every month, so they squeezed this one in between my checks.
Regards
Kent
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
