Autodesk:
Question:
1. Why is it when I do a 3D sketch, make the sweep, then "Return" I always get a constraint error? It tells me that I made a constraint to geometry which is no longer available. The geometry IS available. I always have to delete the constraints just to move on. I'm sure it has something to do with the planes or axis I created while doing my 3D sketch.
2. Why does Adaptively equal inefficiency? The more I use it the more I have to fix those darn cross-part association failures. It takes less time to not use adaptively and use the "old fashion way". Junk. Junk. Junk. Oh - and adaptively rarely, if ever, works correctly with sheet metal parts. I say again - Junk.
3. Would it be so difficult to give us buttons for standard views on our tool bars? You know, like AutoCAD - which I'm sure you have heard of by now. An XY, YZ, XZ, button is all I ask for. You went to the trouble to give us RMB Isometric view but stopped there. I'm sure that there are some programs that someone has written that will do something like standard views but why should I have to go to them to get it? Are the standard views available but I don't know about it? Please advise.
4. Is it too much to ask to provide buttons on the tool bars for Object Visibility? Why make me go through the View, Object Visibility menu three times in a row to turn off User Axis, User Work Planes, and User Work points. It will be six times in a row if you need to turn off the other stuff. Heck, at least make the darn menu tree stay open until I've selected multiple objects to turn on or off. Is that so hard ?????? Again, if I'm missing the boat here please advise me otherwise.
Michael Miller
Day-Brite Lighting
