This doesn't work for me, I even went back removed the extrusion used a fillet, and it still shows the hidden lines on the part. This has to be a glitch in Inventor.
Travis
"Jimmy" wrote in message news:41c08bab$1_1@newsprd01...
If you put a dimension on the radius in Sketch 5 for Extrusion 5 it clears up. You can even go back after the idw has rendered correctly and remove the dimension and it seems to stick.
"Travis (Inv Pro 9 SP1)" wrote in message news:41c08893_3@newsprd01...
I create views on an IDW with this part and one of the holes shows a thru hole through the part... I can't figure out why?
Travis
