Inventor Forum
Why does this part show a thru hidden line?
2 REPLIES 2
110 Views, 2 Replies
I create views on an IDW with this part and one of the holes shows a thru hole through the part... I can't figure out why? Thanks, Travis
2 REPLIES 2
If you put a dimension on the radius in Sketch 5 for Extrusion 5 it clears up. You can even go back after the idw has rendered correctly and remove the dimension and it seems to stick. "Travis (Inv Pro 9 SP1)" wrote in message news:41c08893_3@newsprd01... I create views on an IDW with this part and one of the holes shows a thru hole through the part... I can't figure out why? Thanks, Travis
This doesn't work for me, I even went back removed the extrusion used a fillet, and it still shows the hidden lines on the part. This has to be a glitch in Inventor. Travis "Jimmy" wrote in message news:41c08bab$1_1@newsprd01... If you put a dimension on the radius in Sketch 5 for Extrusion 5 it clears up. You can even go back after the idw has rendered correctly and remove the dimension and it seems to stick. "Travis (Inv Pro 9 SP1)" wrote in message news:41c08893_3@newsprd01... I create views on an IDW with this part and one of the holes shows a thru hole through the part... I can't figure out why? Thanks, Travis
