Inventor General
hhls11
Message 1 of 5 (283 Views)
Why does my derived part turn into a surface part?
283 Views, 4 Replies
11-12-2012 12:09 PM
I am deriving a part from an assembly. After I remove parts that I don't want included in the derived part, the part is automatically switching to a surface part. I was initially trying to use the hole and extrude functions and kept getting errors. I saw that the part was being made into a surface part. How can I fix this? Thanks in advance!
I'm running Autodesk Inventor Professional 2013.
Intel Xeon W3680 @ 3.33Ghz
12GB DDR3 RAM
NVIDIA Quadro 2000 GPU
Windows 7 Professinal 64-bit
JDMather
Message 2 of 5 (273 Views)
Re: Why does my derived part turn into a surface part?
11-12-2012 01:04 PM in reply to: hhls11
When you Derive Component there is an option to derive as Solid or Composite Surface.  I think the default is as Composite Surface body.  SImply edit and change.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
hhls11
Message 3 of 5 (265 Views)
11-12-2012 02:50 PM in reply to: JDMather
I've tried to edit the part, but composite surface wasn't selected. I had derived other parts before this one and they came out fine. It just seems to be this part. I never changed the setting either.
12GB DDR3 RAM
JDMather
Message 4 of 5 (260 Views)
11-12-2012 03:21 PM in reply to: hhls11
Attach the files here.
hhls11
Message 5 of 5 (222 Views)
11-14-2012 12:24 PM in reply to: JDMather
It turned out that a weld was causing the problem. Once I excluded the weld from my part, it worked fine.
12GB DDR3 RAM
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
