Hi Guys,
WHY? Am I getting these error now. Previously, I am not getting it.
Steps to repro;
1. Create a 3D object
2. Goto to VIEW > set Visual Style "Shaded with Edges" > click REFLECTIONS
An error message pop-up
Click "Yes", then a dialog box pop-up
Any info/solution on how to solve this matter is well appreciated.
Hi
Please check your "Application Options \ Hardware settings"
It needs to be set to "Performance or Quality"
If this is the case, then you must restart Inventor for the changes to take effect.
Hi rhasell,
It was set at Performance. I was just wondering what causes this error. Simply because, I do not encounter these issue before. It only started after I use the "SHOWCASE 2012" yesterday.
Please click the compability check box and apply it.
