Inventor Forum
Why? Am I getting these error now. Before, It is working without any error.
3 REPLIES 3
WillieArolf
239 Views, 3 Replies
Hi Guys,
WHY? Am I getting these error now. Previously, I am not getting it.
Steps to repro;
1. Create a 3D object
2. Goto to VIEW > set Visual Style "Shaded with Edges" > click REFLECTIONS
An error message pop-up
Click "Yes", then a dialog box pop-up
Any info/solution on how to solve this matter is well appreciated.
Thanks & Regards,
Willie
Autodesk Inventor Professional 2019
Windows 7, 64-bit
3 REPLIES 3
rhasell
in reply to: WillieArolf
Hi
Please check your "Application Options \ Hardware settings"
It needs to be set to "Performance or Quality"
If this is the case, then you must restart Inventor for the changes to take effect.
Reg
2024.2
Please Accept as a solution / Kudos
WillieArolf
in reply to: rhasell
Hi rhasell,
It was set at Performance. I was just wondering what causes this error. Simply because, I do not encounter these issue before. It only started after I use the "SHOWCASE 2012" yesterday.
Thanks & Regards,
Willie
Windows 7, 64-bit
Yong.Jing
Please click the compability check box and apply it.
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
