No, that doesn't work either.
I don't understand that there isn't anybody who has no problems with this.
Christian
"Aaron R. Friedman" schreef in bericht
news:3FB1839A.30703@excite.com...
> Can you RMB on the parameter and select "Edit Unit Attributes" and turn
> off the trailing zeros? I know you can do that when using parameters in
> a note.
> Aaron
> Christian Niemarkt wrote:
> > I was talking about custom parameters in the partslist.(they are not
> > affected by dimstyles)
> > See also first posting.
> > Christian
> > "Hal Gwin" schreef in bericht
> > news:E626EAAA8526B19B3005BD1DA97CBAD7@in.WebX.maYIadrTaRb...
> >>Yes you can suppress trailing zeros in your dimensions style, it is a
> >>check box.
> >>>There's no option to set the display of the "trailing zero" off ??? Too
> > bad.
> >>>Kathy, do you know which kind of things areaffected by changing the
> > decimal
> >>>points in an ipt?
> >>>I see the decimals of the mass is also affected by this, but luckely
the
> >>>dimensions not. Are there more things I should be aware off?
> >>>Christian
> >>>"KJohnson" schreef in bericht
> >>>news:0BC32F7AE0AE69E5B963A73CD64A77ED@in.WebX.maYIadrTaRb...
> >>>> You need to open the part and go to Tools/Documents Settings and
> >>>change
> >>>>the number of decimal points there.
> >>>>Kathy Johnson
> >>Hal Gwin
> >>Mechanical Designer
> >>Xenogen
> >>W2K SP4
> >>Dell Precision 650
> >>Dual 2.66 GHz Xeon
> >>1.5 GB DDR
> >>Quadro4 900 XGL
> >>nVidia 6.14.10.4472 w/registry update
> >>Dell UltraSharp 19" LCD
> Aaron R. Friedman
> ARF Designs
