Inventor General
Active Contributor
tap90291
Message 1 of 4 (38 Views)
Which cpu for inventor
38 Views, 3 Replies
11-05-2002 12:21 AM
I am upgrading a machine and I am not sure which way to go P4 2.4 533 fsb or AMD XP 2400 (1.93 mhz) 266 fsb. Which one will be noticably quicker if at all.
Thanks in advance
TAP
*Bilton, John
Message 2 of 4 (38 Views)
Re: Which cpu for inventor
11-05-2002 12:54 AM in reply to: tap90291
For single CPU, a P4 will probably be faster. If you are going for a multiple processor system then
the AMD architecture with shared data cache is a lot more efficient at spreading the data over
multiple CPU's and is therefore faster (IMHO).
John Bilton
"It seemed like a good idea at the time..."
*Autodesk, John Elliott -
Message 3 of 4 (38 Views)
Re:
11-05-2002 07:49 AM in reply to: tap90291
You can probably get a dual AMD for much less. I would pack it with as much
memory (even 3GB) as you can afford. Perhaps by a large EIDE drive instead
of a SCSI. Putting all of the data locally is a big plus.
The dual processors come into use when you are making drawings. precise.
John
"John Bilton" wrote in message
news:8846AE87AE3DD4D8E5C490BDA8F7F353@in.WebX.maYIadrTaRb...
> John Bilton
*Corbin, Brian
Message 4 of 4 (38 Views)
Re:
11-05-2002 09:44 AM in reply to: tap90291
I looked at a dual AMD setup but all the motherboards only support 266MHZ
RAM which is a little old now....
"John Elliott - Autodesk" wrote in message
news:F627B9BD8138E6C1BFE8F4F5D41E1C0C@in.WebX.maYIadrTaRb...
much
> John
> > John Bilton
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
