Inventor Forum
Where is the select mode?
3 REPLIES 3
Karol-Or
1213 Views, 3 Replies
I want to change the selection method to feature priority.
Where is the button?
Not in the right click
3 REPLIES 3
Hi Karol-Or,
It might vary depending on the version you using and the file type/ environment you're in, but look on the Quick Acess toobar along the top of the screen.
If you don't see this, then it might be helpful to provide more details on your version and the file type/ environment you're working in.
I hope this helps.
Curtis
JDMather
in reply to: Karol-Or
Try Shift + right click (while not in any command, also try while in another command).
Too slow Chris - did you eat your Wheaties?
