Inventor General
Distinguished Contributor
Karol-Or
Message 1 of 4 (178 Views)
Where is the select mode?
178 Views, 3 Replies
07-11-2013 09:27 AM
I want to change the selection method to feature priority.
Where is the button?
Not in the right click
Curtis_Waguespack
Message 2 of 4 (174 Views)
Re: Where is the select mode?
07-11-2013 09:38 AM in reply to: Karol-Or
Hi Karol-Or,
It might vary depending on the version you using and the file type/ environment you're in, but look on the Quick Acess toobar along the top of the screen.
If you don't see this, then it might be helpful to provide more details on your version and the file type/ environment you're working in.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
JDMather
Message 3 of 4 (165 Views)
07-11-2013 09:44 AM in reply to: Karol-Or
Try Shift + right click (while not in any command, also try while in another command).
Too slow Chris - did you eat your Wheaties?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
cbenner
Message 4 of 4 (162 Views)
07-11-2013 09:45 AM in reply to: Curtis_Waguespack
Shift / Right Click... assuming you are in part or assembly mode.
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
