I have made a drawing template with a title block that has iProperties of Type Drawing Properties, Property, Number of Sheets <Number of sheets> although not listed as a Parameter. Someone suggested that I tag it this way. Similar to what is described as on page 545 of Mastering Inventor 2012 By Curtis Waguespack. I can find the iProperties of the Sheet Number in the Model but I cannot find where to modify the input for the “of” field. Or where does The Format Text, Type Drawing Properties, Property, <Number of sheets>, field link to?
Yours truly C.A. Thaemar
And or what is this Edit Property Fields, dialogue box for. I cannot change “edit” any of the fields. Is it just me or what?
C. A. T.
Solved by freegoodkharma. Go to Solution.
Solved by smilinger. Go to Solution.
Here. It's automatically linked to the number of sheets and the current active sheet no. in your drawing.
Thank you so much, I knew I was doing something wrong I just could not remember what is was!
PLUR Yours truly, C. A. Thaemar
Thank you! I am sorry but you misunderstood my question. For I was where you were telling me to go. I changed the title as you suggested and someone else helped my very quickly. Id est. “Where can I find the Number of Sheets “Parameter””? Thanks to you! I am sorry my English is not too good I am form Texas.
Yours truly,
C.A. Thaeamr
No problems my friend I did not mean for you to start a new thread but it is ok...
I just wish there was a way to change the title..
