Inventor General
New Member
Message 1 of 18 (1,488 Views)
When inserting/importing DWG files into Inventor nothing shows up.
1488 Views, 17 Replies
11-16-2013 05:18 PM
Hi Everyone,
I am using Inventor Pro 2014 on Windows 8.1 and when I insert or import a DWG file from AutoCAD into Inventor to extrude it into a solid, nothing shows up. Apparently a wizard is supposed to pop up but when I try it nothing at all happens. I have tried reinstalling it but nothing seems to work. Has anyone else had this issue? I think importing a DWG into a 2D sketch is a fairly basic thing to do but I'm baffled that it isn't working. Does anyone have any suggestions? I have SP1 already installed.
Myles
*Expert Elite*
Message 2 of 18 (1,467 Views)
Re: When inserting/importing DWG files into Inventor nothing shows up.
11-16-2013 06:04 PM in reply to: mj.penner
Have you done this in previous releases?
Are you familiar with the procedure?
(are you selection Options and setting to Import?)
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
New Member
Message 3 of 18 (1,463 Views)
11-16-2013 06:09 PM in reply to: JDMather
Thanks for the response. Yes when I choose "Open" and pick "Import" from the options button nothing appears. The same is true when I make a 2D sketch and choose "ACAD" from the insert box. Unless there's something key that I'm mising I really don't know why there isn't even an error prompt if something really isn't working.
Distinguished Mentor
Message 4 of 18 (1,376 Views)
11-17-2013 06:11 AM in reply to: mj.penner
Do you have drawing trueview installed and does it run?
New Member
Message 5 of 18 (1,260 Views)
12-13-2013 08:37 PM in reply to: rdyson
I am in exactly the same situation (Inventor 2014 SP1, x64, Windows 8.1), and I have exactly the same problem. Just absolutely nothing happens.
Has anyone found a solution??
I do have TruView 2014 installed, and it does work. I can view all of the AutoCAD files in question perfectly using TruView.
The problem exists for both .dwg and .dxf files. I try a simple file with just a 2D square, still nothing happens.
*Expert Elite*
Message 6 of 18 (1,251 Views)
12-14-2013 04:51 AM in reply to: bwil165
Attach dwg file here.
New Member
Message 7 of 18 (1,239 Views)
12-14-2013 04:32 PM in reply to: JDMather
I cannot attach the DWG I actually intend to use, but any DWG/DXF exhibits the problem. I have attached a simple such DWG (containg just a circle and a square) that exhibits the problem.
Furthermore, I have tried opening the DWG/DXF in Inventor (successfully), then copying the objects (select, right-click, copy) and pasting (activate sketch, right-click, paste) them into an IPT sketch. Again, nothing happens.
Thanks.
New Member
Message 8 of 18 (1,195 Views)
12-19-2013 02:23 PM in reply to: mj.penner
*Exactly* the same problem here... Inventor LT 2014 X64 Trial & SP1 on Win 8.1 - and so, alas, my trial period expired before I was able to verify DWG import which is very important for our intended application.
New Member
Message 9 of 18 (1,007 Views)
01-27-2014 04:47 PM in reply to: bwil165
Have you found a resolution to this issue?  I am having the same problem.  Thanks!
New Member
Message 10 of 18 (995 Views)
01-28-2014 02:00 AM in reply to: badams071
>> Have you found a resolution to this issue? <<
Alas, no - so I deinstalled the Inventor trial and bought Rhino instead.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
