Inventor General
Active Member
ryansmalley
Message 1 of 5 (687 Views)
When I create a simulation the stress analysis ribbon doesn't enable options.
687 Views, 4 Replies
08-07-2011 04:03 PM
What do I need to do to enable the stress analysis buttons? Please answer with screen shots if possible, it would help to see where to click and what to do. Thanks
I am using  Autodesk Inventor 2012 proffesional.
JDMather
Message 2 of 5 (682 Views)
Re: When I create a simulation the stress analysis ribbon doesn't enable options
08-07-2011 05:15 PM in reply to: ryansmalley
Show a screen shot of your Environments tab.
Sown a screen shot of your Tools>Addins
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Active Member
ryansmalley
Message 3 of 5 (646 Views)
08-18-2011 04:51 PM in reply to: JDMather
Here are the screen shots, please help.
JDMather
Message 4 of 5 (631 Views)
08-19-2011 05:14 AM in reply to: ryansmalley
Have you gone through the getting started tutorials for using the Ribbon Interface?
It appears you have set to Compact rather than Normal (see attached image).
Right click on a tab and set Ribbon Appearance to Normal.
Or is something else your problem?
Why does it take 11 days to post requested information?
Active Member
ryansmalley
Message 5 of 5 (612 Views)
08-19-2011 01:00 PM in reply to: JDMather
The problem is when I mouse over the buttons the menu underneath is grayed out. Like when I mouse over the loads button everything underneath is grayed out and I cannot click on anything.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
