Inventor Forum
What's the fillet radius in this diagram? (file attached)
3 REPLIES 3
1499 Views, 3 Replies
Hi, I'm currently enrolled in a PLTW course in my local high school. We have a upcoming project that I decided to get a head start on. The problem is, the diagram the project gives out doesn't give clear dimensions how the radius of the fillet. I have attached two files, the work I've already done and the diagram. I've been looking over the diagram for the better part of the day and I still don't know the exact fillet radius I'm supposed to use. On one of the referenced radiuses, I entered in a figure that appeared to work.
3 REPLIES 3
JDMather
The TYP note means Typical - that is - all the smaller radiii are 0.063 (probably a round off of .0625 since we can't hole fillets to 4 decimal places in manufacturing anyhow).
You are doing great.
Here is another way you might have created that part.
(don't for get to add the .0625 hole.
in reply to: JDMather
Can you save the file in a different file format? I only have the 2011 version of Inventor since that's the version my school uses. I reccomend saving in the .sat file format.
JDMather
It wouldn't do you any good to see without a feature tree.
I made the part with 3 simple revolves.
1. for the wheel
2. for the pin (minus the hole)
3. for the spoke cut (cut angle - midplane 30°)
see attached image
