Try as I might, I cannot find any documentation which provides a lucid and thorough explanation of the BORN Technique.
Can anyone direct me to such?
Solved by JDMather. Go to Solution.
Base Orphan Reference Node
The origin planes and centerpoint (and axis) have no parents and cannot be deleted.
Anything else can be deleted. Anything else forms parent/child relationships.
So as much as possible use only the Origin geometry as datums to anchor your geometry.
Did you really try?
https://www.google.com/#q=BORN+technique+base+orphan+reference+node
Wow, I never knew it had a name. I just always used the origins because they made the most sense.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Thanks JD
Sorry to take so long to get back to this.
Yes, I have visited those pages. However, I take on board your posting in which you say:
I think that I might have been expecting some more complex answer. IPOF: I DO use origin geometry. I just thought I might be missing something.
@rickduley wrote:
I think that I might have been expecting some more complex answer. ...
The very key to the BORN Technique is simplicity.
