There is no message for "Replacement Constraint" in Inventor that I'm aware of. There is one for "Replace Constraint",
however. Is that what you meant? If so, the replace constraint message simply indicates that Inventor is replacing one
constraint with another. This should only happen when Inventor is previewing an assembly constraint, either in the
Constraint dialog or when doing an Alt-Drag constraint placement. It sounds as though you may have been doing the
latter.
Scott Kohls
Inventor Development
Autodesk, Inc
"Laura" wrote in message news:3254562.1096401191282.JavaMail.jive@jiveforum1.autodesk.com...
> I have an iam where a basic block.ipt is grounded. I projected some work planes and "Create Component" - using these
projected work planes. After a couple of hours (when I'm finished of course) - out of the blue, I accidently grabbed
onto the newly created component and was able to move it in (2) axis. Without thinking, I began a constraint to lock it
back onto the basic block and the message "Executing Replacement Constraint" appeared at the bottom of my screen. My
constraints didn't work without messing something up so I cancelled them.
> When creating the new component, I used "symmetric" when sketching the overall shape - symmetric to the basic block
projected workplanes. Those are the (2) axis that are moving around.
> It's not extremely important that this assembly be locked together - it only purpose is to stay adaptive height wise
and that's the axis that is still holding.
> What does that mean "Executing Replacement Constraint"?
