I created a basic part using Inventor and some how something created some parameters out of the blue. I know that I (or anyone else..because I am the only user) didn't create the parameters. The parameters got created automaticly some how and I would like to know how this happened so I can do it again, because it would save a lot of time.
Here are some of the parameters that got created. If anyone knows how they got created I would be most greatfull.
vParam_Title
vParam_Project
vParam_Description
I have included the file that this issue occurs in so maybe someone can figure it out.
Solved by mrattray. Go to Solution.
Those look like they were created using the Exchange Apps add-in "iProperties Manager".
I have made the exact same modifications to similar files but these parameters didn't show up, so I am not sure how they got there to begin with.
Got any ideas?
Yeah, they look like they were made by the iProperty manager I mentioned. I'm thinking if you haven't ever messed with it (the exchange app), maybe somebody else that had their hands on the file has.
ok...Since it is Monday...I may be a thick, but what exchange app are you talking about? Being the IT guy here I know we don't have Exchange loaded on the server (we use outside source for email) so I am not quite sure what you are talking about.
I went out to the sight to see if I could find out something, but the site is giving me an error and won't load. So I can't check there either.
but since I didn't have any Exchange programs running( or installed for that matter), I am unsure why these parameters showed up in one file but not the other 4?
Nope, nobody else has been in it. I was reminded though that for a little while I did have the exchange app "iProperties Manager" installed, but I don't remember having this particular file open with that program running. If I did I should have had the associated parts open as well, but who knows. Maybe I should reinstall it and see what happens.
YES....YOU WERE RIGHT!!!!
I am just a lowly noob..... You are the MASTER......LOL
Had it not been Monday and had I not been so Sloooowww...on the up-take I might have remembered that I had done that when you mentioned it
Did I remember to tell you...YOU WERE RIGHT!!! ???
LOL
