I just installed the 2012 invnetor and was going trew the Tutorials and is not able to see any like in (inventor 2011).
Solved by ted.saufley. Go to Solution.
Solved by Curtis_Waguespack. Go to Solution.
Hi josueocon,
They are online for download in 2012:
http://inventortrenches.blogspot.com/2011/04/where-are-inventor-2012-tutorial-and.html
I hope this helps.
Curtis
I did that allready, but inventor wants to connect to internet everytime for the tutorial and I still can not to see the tutorials am looking for(more like hose routing)
Hello josueocon,
If you have an Internet connection, Inventor 2012 is designed to take you to the tutorial pages on the Autodesk Wiki. Here is a link to the Tube & Pipe tutorials on the Wiki.
http://wikihelp.autodesk.com/Inventor/enu/2012/Help/2144-Tutorial2144/3052-Tube_and3052
Are you unable to access the Autodesk Wiki? Or do you not want to be connected to the Internet when performing the tutorials?
Best regards,
-Ted
