Inventor Forum
Well here's a new one I've never seen
10 REPLIES 10
Message 1 of 11
178 Views, 10 Replies
Trying to place a shaded view of a rather larger assembly and I get this
error (see attached) followed by the ever so popular hex code memory error
and a crash to the desktop. For what it's worth the assy does contain a
VERY larger derived part (with it's link broken)
Nvidia 900XGL 4403 drivers
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
10 REPLIES 10
Message 2 of 11
Never seen that one either. Is it persistent? Maybe the driver is whacked.
~Larry
"Sean Dotson" wrote in message
news:CC112A1A3365F4862C6DC94F70660173@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
Message 3 of 11
i would start with that last suggestion, sometimes it's easier to uninstall
the video card driver and then reinstall it, to fix a problem.
"Larry Caldwell" wrote in message
news:0BC5C493FCA1A54DBD83AE98E0F7E722@in.WebX.maYIadrTaRb...
> ~Larry
error
> > Sean Dotson, PE
Message 4 of 11
I've come up with that message a couple of time, including the out of memory
error. I'm pretty sure that it corrected itself after a reboot. It was a
while ago and my memory isn't what it used to be (but I can't remember what
it used to be either!).
Mark
Message 5 of 11
I'm thinking it's the derived part. 42MB worth. I have saved the derived
part as a SAT file and brought it back in an now it's only 21MB. We'll see
if I can get an IDW out of this line...?
Sean Dotson, PE
> ~Larry
error
> > Sean Dotson, PE
Message 6 of 11
Works fine on all models expect this one. Have rebooted numerous times.
I just may end up blowing all the dust bunnies out of this machine soon
anyway.
I'll try the driver reinstall. Was curious to know from Autodesk what this
error means exactly.
Sean Dotson, PE
> Sean Dotson, PE
Message 7 of 11
Used to see this a lot with Quadro2 cards. Never seen it with a Q4 apart from with one that was about to die (I flashed BIOS and
the card went pop).
Try turning your AGP speed down to see if that helps, and reboot. Very annoying. Another possible workaround is to have another
small IDW open so that IV already has an initialised OpenGL window.
John Bilton
Message 8 of 11
Interesting thought. I'll check into it. Of course if I have the model
open in another window it should have an Open OpenGL window right?
Sean Dotson, PE
"John Bilton" wrote in message
news:ADDE56452A7813FB0AA295275DCFBF59@in.WebX.maYIadrTaRb...
> the card went pop).
> John Bilton
Message 9 of 11
xavierl
I think it's disc format time
I did one driver update to 4403 and have been too scared to do any more updates. the 550xgl I got probably wont get much benefit from any new drivers anyway. pc is running perfect at moment.
only problem I did the iv world cup problem and it gives wrong dimension values in the idw.
Frans X Liebenberg
Message 10 of 11
True, but it don't seem to want to create the IDW environment and initialise OpenGL. This is the single most frustrating problem
I've ever come across in Inventor, and really makes you want to just throw your PC out of the window.
Sorry for bearing bad news
John Bilton
Message 11 of 11
Placing a view other than the assy then placing the assy seemed to work (I
was still teetering on the edge of crashing however). Thanks for the tip
John.
Sean Dotson, PE
news:4535A60D5F2AB475B45BC9CF4BBF0EC1@in.WebX.maYIadrTaRb...
> John Bilton
