Inventor Forum
Weldments, fillet weld
4 REPLIES 4
mads
259 Views, 4 Replies
Hello
I am trying to fillet weld a pipe to a weldneck flange and in order to make a correct welding there have to be app. 2 mm gab between the two parts, but when i do the welding with the gab inv. tells me that the two faces do not interact. Is there a way to make this welding?
Best regards
Mads
4 REPLIES 4
in reply to: mads
Mads,
The 2 mm gap is to wide for Inventor to assume the
parts are suppose to be touching.
For gap welds like this, I use an iPart for
the weld filler material.
John
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Hello
Best regards
Mads
in reply to: mads
Currently you have to use the Cosmetic Weld, as it does not support allowances for distortion. As
Gary said a few days ago "it is work in progress".
Workaround that sometimes works: Assemble the components with faces touching, apply welds, then
adjust assembly constraint to provide you with a gap. Inventor complains, but the weld is still
there and so is the gap. Haven't tried it with a 2mm gap, but it works with a 0.060" gap and a 4mm
weld on 60x40 box section.
John Bilton
in reply to: mads
John,
Does this work with solids that have mass or just cosmatic welds?
Also, after stretching the weld can the weldment be derived into a single
part?
John
"John Bilton" wrote in message
news:DCCE7897B1E1E1E50F4C5D3C16832166@in.WebX.maYIadrTaRb...
> John Bilton
in reply to: mads
Yes, but as I say Inventor complains about it.
>part?
Don't know, give it a try and let us know how you get on (teaching 5.3 essentials today so have not
got access to R6 to try it myself)
John Bilton
