Inventor Forum
Weldment
12 REPLIES 12
Message 1 of 13
Zac-C
683 Views, 12 Replies
Weldment
The file attached contains a main pipe with 4 flanges mated onto the pipe.I have not used the Weldment feature before so would please like some guideance and help.What steps would i use to Weld the 2 small upright pipes on top of the main pipe and Weld the 4 flanges onto the 4 small curved pipes underneath the main pipe?
Any help appreciated.....IJC
12 REPLIES 12
Message 2 of 13
blair
in reply to: Zac-C
First, you need to either convert this existing model to a Weldment, or start a new model as a weldment. Then enter the Weld Module. The rest is straight forward, or read the "Help"
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 3 of 13
Zac-C
in reply to: blair
Blair...thanks for the reply....will take your advice and follow.
Blair is also possible to use Weld where i attached the 4 flanges onto the curved pipes under the main pipe?
Best Regards
IJC
Message 4 of 13
blair
in reply to: Zac-C
Yes, it's done the same way.
Delta Tau Chi ΔΤΧ
Message 5 of 13
Zac-C
in reply to: Zac-C
Thank you
Message 6 of 13
Zac-C
in reply to: Zac-C
I was able to weld the 2 end pipes but was not able to weld the middle pipe.I used the same technique as the 2 end pipes but could not get it to work.I also tried some other welds but again would not work...What technique is required to weld the middle pipe onto the bottom pipe?
Thanks....IJC
Message 7 of 13
blair
in reply to: Zac-C
Your IAM file is useless without the required IPTfiles
Delta Tau Chi ΔΤΧ
Message 8 of 13
Zac-C
in reply to: blair
Here is the file..thanks
Message 9 of 13
blair
in reply to: Zac-C
The files you sent only contain a single part "Part1" and it's a flat plate with a slot and a couple of other holes.
Delta Tau Chi ΔΤΧ
Message 10 of 13
Zac-C
in reply to: blair
Will this picture help..The large pipe in the middle without the weld is the one i cannot get to work... Both pipes are 3" in diameter...thanks again
Message 11 of 13
blair
in reply to: Zac-C
You will probably have to do a Split-Face on the riser pipe. This will give a funny result at the points on the riser pipe.
Your Split-Face line will start at the end-point of the cope of the Riser pipe.
Delta Tau Chi ΔΤΧ
Message 12 of 13
Zac-C
in reply to: blair
Thanks Blair...IJC
Message 13 of 13
eih5
in reply to: Zac-C
Did you ever figure this out?
I am dealing with exactly the same problem, putting weldments on two pipes of same diameter.  I tried to use Split-Face but couln't get this to work. Help would be very much appreciated.
Einar
