I have had issues with holes generated using projected geometry moving off location and assemblies blowing up (two separate issues). I think I have it narrowed down to weldment ****’y files. Hopefully I can communicate it properly (see attached pdf). Also attached is a zip file of the pack-n-go for this ****’y.
The ****’y here is fully constrained and is at the final stages of design. I was adding tap holes for fasteners, generating the first/ starting hole using projected geometry. When I try to make an array from the tapped hole, many of the 3d constraints ‘blow up’. If I drag the cover plate the ****’y snaps back into position but then a failure dialog box appears showing various constraints bad. I do not understand why this is happening.
This morning I tried making the tapped hole without using projected geometry and it behaves the same way. I am near the end of the modeling and need to get the layouts made- very frustrating.
Thank you for the help.
Pete Beau
IV 2013, latest SP & HF’s
Win7, 64 bit
8g ram
Hi beau-tech,
Here's the link to your 4th attachment, it appears that you might have accidentally created a new thread rather than adding a reply to this one. Hopefully this will help others find it:
As for a link to add the Pack and Go files, you might contact Autodesk support via your reseller or subscription account and request an FTP, or create a Dropbox account to use as a host. I think the files will be required to diagnose the issue.
I hope this helps.
Curtis
