Wouldn't you know it, I found the answer to the first part of my own
question... I got this to work by using the "Add Participant" feature and
adding the other parts from the array.
Still don't know why the assembly crashes when I edit the pattern.
Anyone??
Kirk
"Kirk A." wrote in message
news:4154DB2156023F27AF70E4113CB0A186@in.WebX.maYIadrTaRb...
> I posted a file in CF under the same heading. What I am trying to is add
> tapped holes to the right end of this weldment. To do this, I RMB on
Hole1,
> then chose "edit feature" and added the holes. Problem is the tapped
holes
> only go thru the channel. I want the tapped holes to go thru all the
parts
> like on the left end.
> How do I get the holes in the right end without having to do another
sketch?
> Want to crash Inventor 6.0.... Edit Component Pattern 1 and remove either
> 819033-pa or 819033-pd. Crashes my system everytime.
> Kirk
> Inventor 6, sp1
> Win XP Pro
> P4, 2 Ghz, 512M
> Gloria II-64
> nVidia v6.13.10.4072
> 1280x1024, 32 Bit
