Inventor General
Member
Message 1 of 6 (451 Views)
Welding to curved surfaces
451 Views, 5 Replies
05-23-2005 12:38 PM
I am looking to properly represent the way we weld pad eyes on to pipe. In our process we place the base of the padeye tangent to the pipe and fillet weld it to the pipe. I have found several work around's but this will not properly analyses when I pass the model to out FEA program. Does any one have any insight?
*Jimmy
Message 2 of 6 (451 Views)
Re: Welding to curved surfaces
05-23-2005 02:21 PM in reply to: Mark Scott
Will the emboss tool give you what you need?
wrote in message news:4853802@discussion.autodesk.com...
have any insight?
Member
Message 3 of 6 (451 Views)
05-23-2005 02:23 PM in reply to: Mark Scott
I don't think so. It would probably give the visual representation, but not the physical properties I will need.
*Harold Lee \(Autodesk\)
Message 4 of 6 (451 Views)
05-23-2005 04:02 PM in reply to: Mark Scott
Hi Mark,
I've put an example in customer-files (using the same subject). First I
made a weldment assembly using the groove weld tool to get the desired bead
geometry. Please examine the padeye component and note the split features I
used to define the bead surfaces and the work features that control the
beads fill direction. After this I created a new part and derived in the
weldment. The FEA was performed on the derived assembly in Inventor 10
professional. I'm not sure if this will be successful in your FEA software,
or even if I did it accurately. However, it might give you some news ideas
on how to get around the fillet tool limitation.
Harold Lee
Inventor QA
Member
Message 5 of 6 (451 Views)
05-24-2005 07:28 AM in reply to: Mark Scott
Thanks for the work around. It is a bit of work but will give me what I need. Is there any plan to add the ability for the fillet weld to work with flat to curved surfaces?
Distinguished Contributor
Message 6 of 6 (451 Views)
05-24-2005 09:21 AM in reply to: Mark Scott
Hi Mark,
Currently fillet welds handle hole gaps well. (For example: cylinder going through a block which has a hole in it)
I took a look at this case and it has a gap between the two components. The side view image is attached and gap is shown as black lines. Fillet welds don't handle this kind of gap currently.
Gap and groove welds like Harold demonstrates is the recommended solution for this kind of gap case. Thanks.
shekar
PS: I have posted examples on fillet with gap in this NG. Please search if you need additional information.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
