Inventor General
Active Member
Message 1 of 11 (866 Views)
Weld Fill Visibility
866 Views, 10 Replies
03-26-2012 06:43 AM
Hello All,
I am currently having trouble viewing welds on drawing views. The outer line of the weld is visibile but there is no fill or hatching. I have tried to edit visibility settings, etc and nothing works. Also note that other welds show up and that all the physical welds do show up on the assembly models.
Please see attached file for detail.
Mike
Employee
jan.miskanin
Message 2 of 11 (843 Views)
Re: Weld Fill Visibility
03-27-2012 12:11 AM in reply to: mpascoe
can you, please, send me a dataset?
Cheers,
Jan
Active Member
Message 3 of 11 (834 Views)
03-27-2012 05:23 AM in reply to: jan.miskanin
Jan- Can you please clarify. (I'm new to the discussion forum, this is my first post).
-Mike
Employee
jan.miskanin
Message 4 of 11 (832 Views)
03-27-2012 05:55 AM in reply to: mpascoe
Mike,
can you send me files with this issue? Or attach it here?
Jan
Active Member
Message 5 of 11 (829 Views)
03-27-2012 05:59 AM in reply to: jan.miskanin
I cannot send these files as it is against company policy.
Any ideas come to mind without investigating the actual files?
Employee
jan.miskanin
Message 6 of 11 (820 Views)
03-27-2012 06:26 AM in reply to: mpascoe
Can you right click on view, select "Edit View" and "Model State" tab? In "Weldment" part of dialog, which option is checked? Or, can you attach screenshot?
Jan
Active Member
Message 7 of 11 (780 Views)
03-29-2012 10:21 AM in reply to: jan.miskanin
The machining option is checked at the weldment level (See Attachment). But this issue is also occuring with this part in non welded assembly files showing sectioned or breakout view.
New Member
Message 8 of 11 (729 Views)
04-02-2012 01:42 PM in reply to: mpascoe
I am having the same proplem, weld hatching is not displaying in the drawing view.
Active Member
Message 9 of 11 (583 Views)
10-09-2012 07:13 AM in reply to: mpascoe
I am also having this issue, I have added further examples. This issue is really aggrivating, it makes the use of welds in assemblies almost not woth the time because I just have to go back and add 'end fill' annotations in the drawings to correctly display welds. I hope someone has a potential solution!
Active Member
Message 10 of 11 (571 Views)
10-09-2012 07:19 AM in reply to: jcstevens
My issue was with a sub assembly within an assembly. I had to go and remove the welds in question completely and re-apply them. Then update the change throughout.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
